Grouping of disconnects for service - Electrician Talk - Professional Electrical Contractors Forum
Old 12-21-2010, 08:01 PM   #1
Default Grouping of disconnects for service
I am doing an addittion with 150A MB panel and the existing part of the house has a 200A MB panel. I screwed up when I got everything and got 65' of seu for the 150 to go to the meter, but since the panels aren't together I have to group to mb enclosures outside. Now that 65' or most of that 65' is useless since I have to run ser so I can have the insulated neutral. My question is how far apart can I have the the mb enclosures for it still to be acceptable if there both outside on the same wall?
The one for the 200A will be near the meter, but I would like to put the 150A as far away as I can in order to use most of the seu and not have to get as much ser.
ikeberg9 is offline   Reply With Quote
Old 12-21-2010, 08:03 PM   #2
Fried Bologna um um good!
jwjrw's Avatar
As far as your AHJ allows you to have them apart.
Old 12-21-2010, 08:05 PM   #3
child please.....
NolaTigaBait's Avatar
Rewards Points: 14
The NEC doesn't specify a distance...I'd ask the inspector like jw said.
REMOVED
Old 12-21-2010, 10:49 PM   #4
Ya that's what I figured. Thanks and I will post what they tell me.
Old 12-22-2010, 01:11 AM   #5
Rewards Points: 2,000
They have to be in the same room... I really don't see it as a problem but the NEC doesn't agree with me..
Old 12-22-2010, 08:00 AM   #6
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Is the addition attached? That is not a service disconnect, and does not have to be grouped with your original service disconnect.
Old 12-22-2010, 08:38 AM   #7
child please.....
Rewards Points: 14
Good point...I guess I read it as if there were 2 meters(service disconnects) for some reason.
REMOVED
Old 12-22-2010, 03:44 PM   #8
Yes the addition is attached. I would be mounting the enclosed breakers on the outside wall near the meter. The first 200A panel is right by the meter. The wall out there is about 35'-40' long and the meter is on one side and the new 150A is right near the other end of that wall. After reading 230.70 is it really necessary to have a way of disconnecting the service entrance conductors on both panels in one central location, since each panel is a main breaker panel.
Old 12-22-2010, 05:18 PM   #9
evil bastard
Rewards Points: 746
Are you double lugging the meter?
If not, you DO NOT have two sets of service entrance conductors, and you disconnect for the addition does not have to be grouped or anywhere near the service disconnect.
Bargain Disconnects at The HD crazyboy General Electrical Discussion 7 06-02-2010 12:57 AM
100 amp disconnects electagb Electrician Swap 0 01-13-2010 02:36 PM
Fused A/C disconnects user4818 NEC Code Forum 117 11-19-2009 11:02 PM
Luminare Disconnects jbfan General Electrical Discussion 3 06-26-2008 01:46 PM
Code for disconnects at UPS brucelaird Services and Service Equipment 0 03-20-2008 04:45 PM
