Resi guys, favorite panel brand? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree59Likes
Old 11-04-2018, 02:14 PM   #1
Rewards Points: 1,894
Default Resi guys, favorite panel brand?
I'm planning on upgrading my 60A to 200A and relocating it to the garage on the opposite side of the house. Undecided on interior or exterior (brick) wall of the garage, its common here to have them outside, but probably for install convenience by the meter.
I want to make it easy to modify for either for back up generator or even PV in the future. Brands/models would be appreciated.
Old 11-04-2018, 02:20 PM   #2
Rewards Points: 1,273
This is almost like discussing politics or religion. Everybody has their own opinion and are strongly set in their ways.
I have never seen any benefit from using a more expensive panel such as a Square D QO or Cutler Hammer CH. I generally install Siemens brand panels because a lot of the supply houses stock them. I also install Square D Homeline when it works better in that situation.
One thing that you should consider is that anything more than 30 circuits in a panel is getting a bit tight and sloppy. So if you have a lot of circuits, I would install 2 30 space panels. Save space in the main panel for larger loads like future solar, electric cars, etc.
The Following 2 Users Say Thank You to HackWork For This Useful Post:
chongo (05-19-2019), TGGT (11-04-2018)
Old 11-04-2018, 02:53 PM   #3
Rewards Points: 5,550
I am not particularly loyal, but we install almost exclusively Siemens panels for resi work. The only reason is that the supplier for them is close and they have good inventory.
When the time arises, we will match what may be existing in another part of the home or if we are doing a larger panel we will match for breakers if they are in good shape.
Cheers
John
TGGT likes this.
The Following User Says Thank You to Navyguy For This Useful Post:
TGGT (11-04-2018)
Old 11-04-2018, 03:12 PM   #4
Switched's Avatar
Rewards Points: 10,292
It is usually Siemens or Homeline, that is what the supply houses I use stock.
I don't think I have installed a CH/BR panel since I have had my own shop, come to think of it we never installed them at the other shops I worked for either.
Both Siemens and Homeline stuff is good quality, I rarely have issues with either of them.
TGGT likes this.
The Following User Says Thank You to Switched For This Useful Post:
TGGT (11-04-2018)
Old 11-04-2018, 07:05 PM   #5
neutral member
readydave8's Avatar
Rewards Points: 258
Also Siemans and HO! more siemans in the past, more HO nowadays. And some BR, I learned to hate Bryant after putting many in so evidently Cutler-Hammer made some improvements
I don't like ge
Seen CH and QO panels with breakers coming loose of stabs, especially older panels with missing covers (CH would sell cover separate from panel, so there are many around here that never had a cover)
Dave Ruth
Old 11-04-2018, 08:21 PM   #6
Rewards Points: 20,637
Eim a Pirate, soo's me favrite panels are Eaton Br's. What? Yuu doin't like that?
Arrrrrr matey's I'll cut your stairs off with me scabbard
HEY, If chevy and ford can make crappy vans and not look backwards, then I'm in the me too crowd...............
Wiresmith likes this.
Nationalize all foreign owned farmland now. Now.
Old 11-04-2018, 08:22 PM   #7
I think CH BR is pretty much the same a Siemens and Homeline.
One thing that I like is that the Homelines are available here in 30/60 panels, which means plenty of neutral and ground spaces.
The Siemens available around here are generally 30/30 panels which means never enough neutral spaces and you need a ground bar anyway. That $8 really eats into my profit.
Old 11-04-2018, 08:27 PM   #8
Big Question: Who here has ever had a panel failure before the one year warranty is up? Me neither, never happened. In 42 years of work it never happened. And after they pass the one year warranty? F'em all but six boys, you need to keep the six to carry the coffin........
Old 11-04-2018, 08:37 PM   #9
The only problem that I have ever had with a new panel that I installed was a CH-CH panel in which the breakers just popped off. They would not stay on the bus, they might hold for a couple seconds and then would just pop off. I searched and found MDShunk talking about it many years ago on another forum.
It really turned me off the CH-CH.
Old 11-04-2018, 08:52 PM   #10
Rewards Points: 58
I personally like the low trip curves on Square D. Don't know that it actually matters, because all brands sold today meet the listing requirements, but it's a feel good thing to me.
Sent from my Moto Z (2) using Tapatalk
Old 11-04-2018, 09:17 PM   #11
EJPHI's Avatar
Rewards Points: 12
I like Square D QO because you can get a copper bus if you order the right ones. They finally came up with 2 pole AFCIs for MWBCs.
Oh and I am from Milwaukee so go Brewers for what its worth.
They still do not offer a EUSERC panel though.
The Seimens panels have a partial copper bus, but the bus on the POCO side is Aluminium connected with sheet metal screws.
CH CH sounds interesting.
Old 11-05-2018, 07:55 AM   #12
Going_Commando's Avatar
Rewards Points: 1,620
Same. Regardless of application we now install predominantly Square-D. We do have some temp services built with GE panels, which is nice, because the carpenters never bitch about breakers tripping.
Old 11-05-2018, 08:07 AM   #13
MikeFL's Avatar
Rewards Points: 840
I like having a MDP for all the heavier loads and a MLO for all the lighting & receptacle branch circuits in a single family. It just makes for easier working in the panels.
As to inside or outside, inside sure is nicer at 3am during a storm when you want to know why that one circuit is dead.
As to the ATS that would be easier outside but I'd still put everything inside.
As to brand, whatever is going to have parts immediately available in your area when you need something as others have said.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 11-05-2018, 10:45 AM   #14
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 628
Come on Hax, you and I both know the FPE is the go to brand.
HackWork, tmessner and Bird dog like this.
Old 11-05-2018, 11:15 AM   #15
sbrn33's Avatar
Rewards Points: 3,556
I go with Siemens 90% of the time. I like their neutral set up way way better than qo. I only use the copper buss though.
Old 11-05-2018, 11:23 AM   #16
460 Delta's Avatar
Rewards Points: 1,704
I don’t do residential, but when I put in a lighting panel I generally want a CH series panel. I like the way they’re put together, the bus issue is a new one to me. Was it one of those we made a bad run kind of things?
micromind for moderator- make ET more industrial
Old 11-05-2018, 01:56 PM   #17
Rewards Points: 1,591
Leviton.
Just kidding.
Siemens. I used to be QO but I had a run of bad breakers. I don't give a rat's ass about copper buss. I never even thought about it before ET.
HackWork and Navyguy like this.
Old 11-05-2018, 03:51 PM   #18
Originally Posted by 99cent$ View Post
Leviton.
Just kidding.
Yeah, you can't even get the PL copper bus Siemens panels from supply houses around here because only homeowners would buy them.
The only thing that they have are the ES series, but those don't have enough neutral spaces, which is why I like the Sq D Homeline 30/60 panels.
Old 11-05-2018, 04:38 PM   #19
Rewards Points: 2,993
Homeline. Cheapest and most readily available where I was last time I needed one. I don't install panels often.
AK_sparky is offline   Reply With Quote
Old 11-05-2018, 04:39 PM   #20
sbrn33's Avatar
The copper is something like $6 more, hell why not?
Panel change - How do you guys label your circuits NDC Residential Electrical Forum 36 05-30-2018 03:08 PM
Working on panel - safety instructions for Gen Mgr conclavicus General Electrical Discussion 24 05-19-2018 10:43 PM
Need advice for mouting a pony panel NDC Canadian Electrical Forum 10 04-05-2018 02:52 PM
Calcul maximum electric panel size martindag General Electrical Discussion 12 03-06-2016 05:23 PM
