Resi guys, favorite panel brand? - Page 6 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree59Likes
Old 05-18-2020, 04:53 PM   #101
Rewards Points: 64
Originally Posted by JoeSparky View Post
My favorite panel brand is any brand fuse panel. My 2nd favorite is Federal Pacific. My 3rd favorite is Zinsco. All of the above have made me more money then any other panel
Why did you leave out the Wadsworth breaker panel?
Quickservice is offline   Reply With Quote
Old 05-18-2020, 05:00 PM   #102
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 410
Originally Posted by Max C. View Post
Apparently, Homeline equipment is competitively-priced when ordered in-bulk, which is why you'll often see them in apartments and condominiums.
Yeah, some of the ones we have installed were ordered bulk (insert kits for amalgamated fuse panels)... we didn't order them, we only helped install them (we worked as a subcontractor for another EC)
Same here. How many have you seen locally? Also, how available the breakers? One guy I worked for insisted on using a BR breaker instead of sourcing a compatible two-pole 30 from GE...
I have seen maybe 5 GE panels in the houses I have worked in. Breakers are plentiful here. There's at least 3 different suppliers that carry the breakers.
I don't like GE panels because of their weird spacesaver breaker design.... wanna add a 1p 15a breaker? Well you need a panel filler...
Vote Kevin for Moderator!
Old 05-18-2020, 05:55 PM   #103
460 Delta's Avatar
Rewards Points: 1,732
While the Wadsworth panel is really dated, they were solidly built and are still in use in several plants I work on. Breakers are still available from a local vendor at a price that is reasonable considering the age and scarcity of them.
micromind for moderator- make ET more industrial
Old 05-18-2020, 06:29 PM   #104
Rewards Points: 2,945
Other than their age, there have been no reliability problems or recalls having to do with those panels or breakers. People get their homeowners insurance cancelled over fuse panels.
Fuse panels are generally safe when they are not tampered with. However people tend to screw oversized fuses, or pennies in which makes them unsafe.
Both Zinsco and FPE had problems with the breakers and the bus bars. They both are a fire hazard. Any customer with one of those, I suggest they sell their wife and mortgage the cat and knock off a convenience store if necessary to get those panels replaced. Under the right set of circumstances, they could lose their house in a fire due to one of those defective panels.
MTW and Kevin_Essiambre like this.
Kevin for Moderator
Swampy doesn't want the job
* Make Electriciantalk Great Again! *
Old 05-18-2020, 07:16 PM   #105
MTW
Rewards Points: 11,414
FPE's are literal fire starters, I changed one last winter that was actually melting down and got so hot it charred the plywood backboard. The lineman cut the service drop at the pole before the house burned down, he was there already to investigate loss of power to the house and discovered the FPE main breaker in meltdown mode.
Kevin_Essiambre likes this.
Old 05-18-2020, 09:33 PM   #106
Rewards Points: 850
Originally Posted by kevin_essiambre View Post
i have seen maybe 5 ge panels in the houses i have worked in. Breakers are plentiful here. There's at least 3 different suppliers that carry the breakers.
I don't like ge panels because of their weird spacesaver breaker design.... Wanna add a 1p 15a breaker? Well you need a panel filler...
Wow, out here I've only ever seen two (in homes). Seeing 347V GE panels in older commercial buildings isn't too uncommon, though. City Electric (the one supply-house in-town which sells their equipment) doesn't appear to keep any regular stock on the shelves.
Kevin, you aren't the only one who hates those spacesavers!
Max C. is offline   Reply With Quote
Old 05-19-2020, 05:42 AM   #107
Rewards Points: 64
Originally Posted by Kevin_Essiambre View Post
That's the one I forgot to mention... I'd like to try one out. I like that the neutrals can be landed during the rough in... I'd only use a Leviton panel for new construction though.
I have seen the Leviton Ad’s, but no one around here is stocking them - yet. Where are you finding yours, Graybar?
Old 05-19-2020, 09:04 AM   #108
Beam Me Up Scotty
Rewards Points: 410
Futurplus.
I have some friends that works there... they were supposed to get me pricing on a tub, the hub kit, and an assortment of breakers. They have one hanging on their wall. Next time I'm there I'll take a photo.
Old 05-19-2020, 02:16 PM   #109
joe-nwt's Avatar
Rewards Points: 1,860
Futurplus.
6 month after it's unveiling, I wonder if it will ever become commonplace?
Max C. likes this.
Old 05-19-2020, 02:28 PM   #110
Rewards Points: 850
Here's a couple Leviton unboxing videos. Personally, I'm still unconvinced...
Old 05-27-2020, 05:26 PM   #111
WannabeTesla's Avatar
Rewards Points: 14
Am I the only one Gorilla taping pennies into empty Corn Flakes boxes and calling it good?
WannabeTesla is offline   Reply With Quote
Panel change - How do you guys label your circuits NDC Residential Electrical Forum 36 05-30-2018 03:08 PM
Working on panel - safety instructions for Gen Mgr conclavicus General Electrical Discussion 24 05-19-2018 10:43 PM
Need advice for mouting a pony panel NDC Canadian Electrical Forum 10 04-05-2018 02:52 PM
Calcul maximum electric panel size martindag General Electrical Discussion 12 03-06-2016 05:23 PM
