Sq D hubs vs Milbank hubs - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 1 Post By tmessner
Unread 07-22-2019, 02:24 PM   #1
cool cat
Rewards Points: 301
Default Sq D hubs vs Milbank hubs
Will a Milbank meter hub(A7517) will fit a SQD QO meter/combo panel which requires an A200 hub(type A openings)??
dogleg is offline   Reply With Quote
Unread 07-22-2019, 03:27 PM   #2
FishinElectrcian's Avatar
Rewards Points: 74
Nope usually a touch off if you're desperate you can tap two holes and make it work. If I remember right it's off by about 1/4". Annoying but true.
FishinElectrcian is offline   Reply With Quote
Unread 07-22-2019, 05:04 PM   #3
cool cat
Rewards Points: 301
Aggravating yes I guess Ill order one on Amazon, I talked to Graybar they would have to order. Thanks.
Unread 07-22-2019, 05:06 PM   #4
Rewards Points: 1,199
Did you try Home Depot? The last time I needed a SqD hub I was surprised to see that a nearby HD had them in stock. Not all of the HD's had it, but one that wasn't too far away. However, this was the 2-screw oval style hub.
Unread 07-22-2019, 05:32 PM   #5
cool cat
Rewards Points: 301
Home Depot is a two hour drive one way.Hey but the good thing is not much traffic from job to job.
Unread 07-22-2019, 06:25 PM   #6
MikeFL's Avatar
Rewards Points: 386
Send Uber and you'll have it in 2 hours.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Unread 07-22-2019, 08:09 PM   #7
Rewards Points: 21,788
No they are not interchangeable
two different bolt centre line pattern useally about 1/4 inch or so differnent. so it will not line up unless you retap or make a oval opening for it and use rubber washer to cover the opening.
Unread 07-23-2019, 05:29 PM   #8
cool cat
Rewards Points: 301
Question
The Sq d A type hub is not oval shaped it is more traditional 4 hole square type like midwest ,ge,Siemens ,Milbank,all are just a little different I thought.On the HD website it described the sq D A style hub as "universal".
Unread 07-23-2019, 11:34 PM   #9
Rewards Points: 832
Sorry guys. I think the SqD meter hub and the Mibank hub are the same thing. I forgot to check this morning when I was in the shop.
dogleg likes this.
tmessner is online now   Reply With Quote
Unread 07-24-2019, 12:14 PM   #10
Rewards Points: 832
I checked this morning. The Milbank hub is a perfect fit to a Sq D meter-main loadcenter.
HackWork likes this.
Unread 09-03-2019, 03:56 PM   #11
Rewards Points: 162
Default John R retired electrician from Fed Gov
I have SQD hubs us to 2" and they are only 2 holes but will adjust forward or back. We use milbank meters and they are 4 holes. I would say that a SQD meter hyubs would also be 2 holes.
John R is offline   Reply With Quote
Unread 09-03-2019, 08:36 PM   #12
Rewards Points: 832
Sq D meter main hubs are not the same as the B200 that fits their RB type panels.
Unread 09-03-2019, 08:53 PM   #13
Rewards Points: 162
Since we don't use SD meters i really don't know. You are probably correct.
Unread Yesterday, 11:38 PM   #14
Rewards Points: 1,150
Only hub that would most 3R equipment made for interchangeable hubs is a Unicorn U-Hub, they were made to fit pretty much all makes, Milbank bought Unicorn Industries and to my knowledge they are no longer made.
Norcal is online now   Reply With Quote
