Suspicious looking interior loadcenter - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
  • 3 Post By 99cents
  • 2 Post By MikeFL
  • 2 Post By HackWork
  • 1 Post By sbrn33
  • 1 Post By splatz
  • 2 Post By joe-nwt
Old 04-04-2019, 08:37 AM   #1
Semper Fi
Southeast Power's Avatar
Rewards Points: 7,154
Default Suspicious looking interior loadcenter
A GC we work with sent this photo and asked if we could install a 50amp car charger receptacle for a buddy of his.
He sent this photo of the loadcenter we are supposed to get a circuit out of:
https://www.dropbox.com/s/t2z3rkmva0...23_1.jpeg?dl=0
Something looks suspicious.
It has too many upper breakers to be a sit-bus panel. Not sure why the twin breakers were used and crowded up in the bottom with spaces available.
Old 04-04-2019, 08:45 AM   #2
Rewards Points: 9,583
What I find suspicious is a pest control sticker on the panel. You sure you want to open that thing up?
cwsims84, lighterup and Takideezy like this.
Old 04-04-2019, 08:50 AM   #3
Look at the other sticker below the breakers HVAC, is that who installed it?
ElectricMatt is offline   Reply With Quote
Old 04-04-2019, 08:58 AM   #4
MikeFL's Avatar
Rewards Points: 1,642
Just looks like a 200A (if I can read that blur) MLO in a commercial facility.
Why did they group those breakers that way? Who knows.
Can you add the car charger to it? I'd suggest someone needs to do a load calc (which I always say when adding a load but I know Hack is going to chime in and say just add the load and don't worry about capacity).
MechanicalDVR and cwsims84 like this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 04-04-2019, 09:02 AM   #5
Rewards Points: 918
That's not true.
How dare you besmirch my good name? How dare you, Sir?
cwsims84 and MikeFL like this.
There are 2 types of electrician... Those who knowingly break code, and those who lie about it.
Old 04-04-2019, 09:05 AM   #6
CoolWill's Avatar
Rewards Points: 2,450
According to that diagram on the door, it is a split bus. It does seem to have too many spaces up top, but the diagram shows they're clearly separate buses.
I'm With Her! Hillary 2016
Southeast Power (04-04-2019)
Old 04-04-2019, 09:26 AM   #7
Rewards Points: 918
Normally a split bus diagram would show one bus powered from the other one. That one doesnít. Odd.
MikeFL and Southeast Power like this.
Old 04-04-2019, 09:30 AM   #8
sbrn33's Avatar
Rewards Points: 3,074
Those empty spaces are where the main lugs are. That panel needs changed anyway, especially if they can afford a tesla.
The Following 2 Users Say Thank You to sbrn33 For This Useful Post:
Southeast Power (04-04-2019), Takideezy (04-04-2019)
Old 04-04-2019, 10:05 AM   #9
Rewards Points: 2,476
Normally a split bus diagram would show one bus powered from the other one. That one doesn’t. Odd.
That diagram isn't what it appears to be, it's not a split bus. The top and bottom are two separate diagrams, I think main lug and main breaker. There are 30 spaces in the top diagram, all present and accounted for. The bottom diagram the main is backfed upper right. The squiggle part is to indicate the middle is omitted.
CoolWill likes this.
Old 04-04-2019, 10:22 AM   #10
CoolWill's Avatar
Looking at it on the computer, I think you're right. This is just a panel where someone wanted to separate the DPs from the Spa.
Old 04-04-2019, 10:29 AM   #11
Rewards Points: 58
Diagram shows 15 spaces, panel has 16. maybe not the right cover?
I wouldn't commit to anything without opening that panel first.
Bird dog and MikeFL like this.
The Following 2 Users Say Thank You to joe-nwt For This Useful Post:
Bird dog (04-04-2019), Southeast Power (04-04-2019)
Old 04-04-2019, 08:13 PM   #12
Rewards Points: 2,957
I just learned about split-bus panels. I've never seen or heard of them before. Very interesting.
AK_sparky is offline   Reply With Quote
Old 04-04-2019, 08:36 PM   #13
Rewards Points: 2,924
I'd like to see it with the cover off. Here's a zoom of the label.
Greg
Old Today, 10:54 AM   #14
cwsims84's Avatar
Rewards Points: 145
Why not just cruise over there, crack that bad boy open and then make a well informed decision on what you can and canít do.
cwsims84 is online now   Reply With Quote
Old Today, 12:55 PM   #15
Semper Fi
Originally Posted by cwsims84 View Post
Why not just cruise over there, crack that bad boy open and then make a well informed decision on what you can and get do.
I went over and... its a regular 30/40 garden variety load center. All of those spaces are for the taking. There is only one more "notched out" bus for twin breakers above the existing twins. The other spaces are for full size breakers.
