Transformer Primary Conductors Calculation - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By Tonedeaf
Old 05-23-2019, 01:40 PM   #1
Rewards Points: 14
Question Transformer Primary Conductors Calculation
Hey Guys,
We have a Solar system installed with the following specs:
- Voltage: 480 V
- Current: 1080 A
This is fed into the secondary of the 1000 kVA transformer with 4kV on the primary whose spec. is:
kVA= (1.732 x 480 x 1080)/1000 = 897.895 kVA (1000 kVA is used)
From this the primary current will be:
I = 897.995*1000/1.732*4000 = 129.6 A
The primary is interconnected to the grid
The POCO asked us to use a 2/0 wire for the primary, but I wanted to verify this so, Can someone please provide a step by step process to calculate the conductor size for the primary according to NEC?
Thanks in Advance
The_Electrician is offline   Reply With Quote
Old 05-23-2019, 05:13 PM   #2
Rewards Points: 990
you gota use what the POCO wants, they have their own guidelines for services and they do not necessarily use the NEC.
around here u can use #2 awg Cooper MV cable for that load.
Tonedeaf is online now   Reply With Quote
The Following User Says Thank You to Tonedeaf For This Useful Post:
The_Electrician (05-23-2019)
Old 05-23-2019, 05:34 PM   #3
Rewards Points: 14
Hey, Thank you, did you come up with #2 using 310.15(B)(16) 90 degree Temp.? Also, do I have to install a primary side protection for even if I am connecting directly to the utility line?
Old 05-23-2019, 05:46 PM   #4
Rewards Points: 990
we have to use 15KV cable and terminations for 4160V....utililites around here don't want to stock 5kv stuff and they are trying to phase out 4160.
15KV XPLE #2 awg cooper xple or epr is good for 150-165 amps in duct. I think its 90 table
The_Electrician likes this.
Old 05-23-2019, 06:04 PM   #5
Rewards Points: 14
Now I got it!, I couldn't find table 90 is it in article 310?
Old 05-23-2019, 06:15 PM   #6
Rewards Points: 990
https://www.mysouthwire.com/medias/s...4088417310.pdf
here's tables from southwire
90 degree induct #2 good for 150 amps
Old 05-23-2019, 06:25 PM   #7
Rewards Points: 14
Thanks man, appreciate it. I have one more doubt, Do I have to have a primary protection for the transformer like a service disconnect even if I connect the primary of the transformer directly to 4kV line of the utility?
Tags
#primary, #transformer
3 Phase Transformer load calculation TOOL_5150 Commercial Electrical Forum 6 06-26-2017 12:56 PM
Pull Box size calculation - Parallel conductors TOOL_5150 NEC Code Forum 7 03-21-2017 12:08 AM
Transformer Primary protection rossi32s Industrial Electrical Forum 5 11-08-2016 01:58 AM
Transformer Calculation Aegis General Electrical Discussion 2 06-01-2016 03:39 PM
Three phase Wye Transformer KVA calculation/ Homework typo? JasonCo General Electrical Discussion 3 03-11-2016 08:02 PM
