A client has asked me to install 110v socket outlets in his factory for general power tools. Would you say the best way to do this is just to get site transformers and plug them into 230v supply's or is there an easier more effective way
What the hell is an elecrician?:001_huh::001_huh:May be getting our wires crossed. It is an elecrician forum FOR elecrician
Haha!!My stupid t is jammed!!:laughing:What the hell is an elecrician?:001_huh::001_huh:
I should not be on here cause I'm not one of those.
It is true...they use an isolated power system similar to what is used in hospitals over here. The 120 volts is derived from a center tapped transformer with 55 volts from phase to ground.This is really timely... I recently heard that pro level power tools/any tools used on a building site must be 120v in the UK-true?
I heard it was for safety.
If you're in the UK why are they using 120V tools in this factory.The factory pre manufacture buildings then put them together on site. So they are using 110v drills and jig saws etc
Because it's required.If you're in the UK why are they using 120V tools in this factory.
It'd be MUCH easier to get the right tools for the job and for the location.
