I would not mess with a listed fixture. If the fixture is 12V and not rated for LED I don't know how you could configure it to work as the LED's use a driver to communicate much the way a printer on the pc is used to recognize the printer. Therefore modification of the fixture may be necessary. That being the case you have nullified it's listing and that is a no-no here in the states.
I have read that it is inefficient NOT to wire LED's in series. Here is a resistor calculator needed for LED's
Sorry I can't help any further as I really don't understand the nuances involved with LED. I also don't know why some tranies won't work with a minimum wattage but I have seen it make the lights blink and act weird.
