Id say 5 to 10 minutes could be an understatement depending on how much excess current is being drawn. If you look at the time current curve for the specific brand it will give you a pretty good idea of what the breaker can handle and for how long.In my course the instructor mentioned how a 15A breaker can go over its limit for 5 to 10 minutes then it will trip. Anyone noticed this or is it certain brands?
They're supposed to for a few seconds to handle inrush current , but not 10 minutes..:laughing:In my course the instructor mentioned how a 15A breaker can go over its limit for 5 to 10 minutes then it will trip. Anyone noticed this or is it certain brands?
Well, technically they can. Since breakers are man-made machines, they're fallible. Not only will there be a certain +/- tolerance, but they may change over time. I've seen 20a breakers trip at 12-13 amps.I agree, 480 got it.
The only thing the number on the handle means is that a breaker will never trip at less than that ....
Little-known fact: Mr. T always carried an FPE breaker in his jumpsuit on The A-Team so he could weld anytime, anywhere.I still think you can weld an 18 gauge plated steel semi truck with a 15 amp FPE before it trips.:whistling2:
Pretty sure Big John ran some FPEs through a breaker testing machine and they passed.I still think you can weld an 18 gauge plated steel semi truck with a 15 amp FPE before it trips.:whistling2:
MTW actually sent me a bunch of others to test. I screwed up because today has been the first slow day in a while, would've been a good one to try.Pretty sure Big John ran some FPEs through a breaker testing machine and they passed.
I tested somewhere between 15-20, 15, 20 and 40 AMP FPEs all tripped in a reasonable amount of time for Long TIme and Instantaneous operation.Pretty sure Big John ran some FPEs through a breaker testing machine and they passed.
It seems I got my BJs confused. :jester:I tested somewhere between 15-20, 15, 20 and 40 AMP FPEs all tripped in a reasonable amount of time for Long TIme and Instantaneous operation.
This was over 3 years ago.
Just so you don't expect a BJ, we're good.It seems I got my BJs confused. :jester:
You don't know which BJ?It seems I got my BJs confused. :jester:
I doubt either of you look good topless with a miniskirt and heels. :jester:Just so you don't expect a BJ, we're good.
