I was going to put a 35kw generator in with a dual 200amp transfer switch. It turns out that the area has low gas pressure so I spoke to sales rep and 20kw can now run on 3.5wc and that is perfect the area will guarantee 4wc.
I'm planning on putting the 2 20kw generators in this week with 2 separate 200amp transfer switches. Each transfer switch will be feeding a 200amp panel. My question is will it be ok to have the 2 generators on the same neutral? I think it will but I'm starting to have 2nd thoughts. I don't know if it would somehow make a surge since it will be from 2 separate sources. But then I was thinking that there can be 2 house right next to each other off the same transformer and both have generators. The neutrals would be tied together at the pole so it would be the same thing. The reason this make me nervous is because I was doing a generator install on a split 400amp service and It was a CH panel with the ground strap so as normal I separated the grounds and neutrals. I removed the ground strap and turned the utility power on then I heard the transfer for the security system burn up and the furnace sounded like it was running slow. The short version is the opposite side neutral bars was getting the neutral from the back of the box and when I removed the strap there was no more neutral, it caused a surge some how and ended up costing me money in repairs to some appliances.
