1 - 8 of 8 Posts
Hello, I would appreciate your input on this. I am estimating on a job that involves feeding two 30A MCCs from one 60A feed (outdoors). I was going to give two options depending how much cost is a factor.
Option 1: running 6/3 teck from elec room (fused 60A) to 60A rated disconnect feeding 70A splitter. Out of splitter, two seperate fused 30A disconnects to feed individual MCCs with 10/3 teck.
Option 2: No splitter, no 30A disconnects, same 60A disc. Install two individual 10/3 teck cables to load side of disconnect (two #10s per lug). I was going to make sure the control panels were within 7.5m of the disc as per CEC tap conductor rules. I will then install a fuse block in each control panel since they are not already fused inside (30A max).
Everything Nema 3R
I like option 1. Does anyone see a problem with option 2?
Discussion Starter · #2 ·
Sorry, the picture attached is of a 30A disc installed in a similar way (2 #14s per load lug) just an example pic I found. By the way everything is 600V 3 phase. Thanks
electricsugarman said:
Hello, I would appreciate your input on this. I am estimating on a job that involves feeding two 30A MCCs from one 60A feed (outdoors). I was going to give two options depending how much cost is a factor. Option 1: running 6/3 teck from elec room (fused 60A) to 60A rated disconnect feeding 70A splitter. Out of splitter, two seperate fused 30A disconnects to feed individual MCCs with 10/3 teck. Option 2: No splitter, no 30A disconnects, same 60A disc. Install two individual 10/3 teck cables to load side of disconnect (two #10s per lug). I was going to make sure the control panels were within 7.5m of the disc as per CEC tap conductor rules. I will then install a fuse block in each control panel since they are not already fused inside (30A max). Everything Nema 3R I like option 1. Does anyone see a problem with option 2?
Personally no.
But doubt switch is approved for two wires under one lug.
I know with tens twisted together then tighten down no worries but don't know what inspections opinion would be
Besides being hackish, unless the lugs are approved for multiple wires,you can't double lug.
I have only seen approved oval shaped lugs on larger sized equipment.
Besides, option one will have more profit (unless you quoted using option 2)
1 - 8 of 8 Posts
