You finished reading it yet ?? 😁It’s here!!
No need to read it.You finished reading it yet ?? 😁
Lol no. Too busy lately.You finished reading it yet ?? 😁
6 and 9 seemed to be a waste of paper.Lol no. Too busy lately.
I did take a quick glance and noticed a few things.
-Low voltage is now up to 1000v
-The bonding of the switches thing removed
-Tables 6,9,11 and 19 have changed. Seems odd at first but I think it might actually be better, need more time to check them out.
-Table 1-4 now have a column for the mm2 of each conductor.
-Table 39 is gone and so is the rule that said we could use it (4-004(22).
-and the weirdest thing.......There is no longer an index at the back of the book.
No 39 ? Thats rough. And the loss of index is weird. Maybe because they want to push the digital pdf with the search function?Lol no. Too busy lately.
That was my first thought as well but I have not found anything yetTable 39 and the code with it too !! That's a fairly major change.
Wonder if there is just a new rule somewhere, or the load calc is different ? adjusted amperage on tables ??
No kidding! And they only save 30ish pages out of 941 (2018)..... Tests with the random mostly obscure stuff would be a pain to try and find. Or tests will be done with an ereader with a codebook pdf on it?I won't find anything without the index. I wouldn't want to write a test without it either.
Tim.
Works out well if you have a IP-68 rated panel enclosure in the basement 🙃So if the sump pump is in the basement, the receptacle has to be 1-2ft above the first floor level?? Those pumps better come with longer cords I guess...🤷♂️🤷♂️
No it doesn't! IP ratings by themselves are not acceptable. 2-402 Table 65, you would nee a type 6 or 6P depending if its a temporary or prolonged submersion. I can only imagine what the cost of that is. But we can flood the panel as long as the receptacle stays dry lol.Works out well if you have a IP-68 rated panel enclosure in the basement 🙃
IP-68 = Nema 6P (for the most part)No it doesn't! IP ratings by themselves are not acceptable. 2-402 Table 65, you would nee a type 6 or 6P depending if its a temporary or prolonged submersion. I can only imagine what the cost of that is. But we can flood the panel as long as the receptacle stays dry lol.
Huh, you made me have to go back and check. US only, weird.With the 8-304 16 outlets on a 20A circuit, I wonder if at some point we won't end up where the NEC is with 15A receptacles being allowed on 20A circuits.
How kind of CSA to make us apprentices sweat a little more during the IP!and the weirdest thing.......There is no longer an index at the back of the book.
