Status
Not open for further replies.
1 - 3 of 3 Posts
We bought a piece of food processing equipment that has a 20amp 250v 3 phase 4 wire plug. Any adapters or way to modify to work with the 50amp outlet below?
Outlet: 50 amp, 250 volt, nema 15-50r, 3p, 4w, flush mtg receptacle, straight blade, industrial grade, grounding, 3-phase
Let me know if I need a whole new outlet?
Many thanks!
Protect the wire, protect the equipment. I'm sure if you have to ask if a shortcut is ok, then it probably isn't.
Sent from my SM-G998U using Tapatalk
Estwing magic
Please hire an electrician. This is not optional. Judging by the nature of your question, it will be dangerous for you to work on this equipment and the wiring supplying it.
This thread is closed.
1 - 3 of 3 Posts
Status
