There's a great licensed and insured electrical contractor in your neighborhood. Contact him.I understand that a minimum wire size of #3 or #2 aluminum would be sufficient for installation and wiring from a natural 20K generator and if so, does this apply to a 100 amp output to the switching panel before the main circuit breaker loadcenter? It is also stated that the max ampere output on this setup would only be 75amp and I need to supply the whole house circuitry which is presently a 200 amp set up. What generator size should be used and what conductor to the transfer box / load center panel which uses a 200 amp main breaker.![]()
