It can be used for more than one device but there are limits. What are you trying to power with the AUX 24 volts?Hi,
Are you allowed to double up wires on the 24 VDC Auxiliary Power in a Fire Alarm panel?
Will this pass verification?
Thanks!
There is an ice cube relay already powered by the FA panel for the 120VAC dampers and will need another source of 24VDC AUX PWR for the sounder base for the smoke devices.It can be used for more than one device but there are limits. What are you trying to power with the AUX 24 volts?
