1 - 15 of 15 Posts
Is it 120/240 Single phase or high leg delta? More information will help you here.
A high leg delta. The way it is wired...one of the phases is unused and the other two are feeding a single phase subpanel. We want to install a PV system. So we want to know whether there is a cost effective way of changing the voltage configuration without having to install 3 single phase inverters.
Check the listing of your 208 volt inverter. If it's good for 208 volts, it should be good for 240 volts -- since it's less overall current. And all the insulation ratings should be good for 250 volts anyway.
If not, then three 1-phase inverters will probably be cheaper than putting in a 208-240 volt, 3 phase transformer.
What's the kVA rating and manufacturer name of the inverter?
Discussion Starter · #11 ·
It is a small system. 13.08kW system and the inverter is:
http://www.svssolutions.com/wp-content/uploads/2012/08/SPR-10001f-1-UNI-SPR-11401f-1-UNI.pdf
Both of those links are getting flagged for me as malware. But if you can open and view them, it should be self-explanatory. Or, just call the manufacturer and ask to speak with one of their technical support people. I'm sure they will be able to answer your question.
· Bilge Rat
motors and controls.........
How difficult is that? I am assuming also expensive..
Around here, the POCO will swap a delta bank for a wye at no cost. They're trying to get rid of deltas, especially pad-mount.
If they're pole-mount and all 3 are the same size, they'll simply re-connect then internally and re-connect the service drop to a wye.
1 - 15 of 15 Posts
