I am dealing with this on a job for a contractor of mine and I'm getting a lot of heat (because he has an antiquated electrical system and its my fault . you know the type) the problem is Im having trouble finding out anything. I got the jest of it and the fact that the ground and the 3rd phase are one in the same but go to different areas .And that I cant fuse the grounded phase in a distribution situation. What I don't get is why I have wacky amp readings like (phase A 73amp /phase B the grounded leg has 93 amps and the phase 3 has 83 . Its not the motor I swapped phases on that to rule it out . The motor is a 25 hp 3 phase and at 240 v should draw 65 amp. WTF
