One way is to install a two to one winding ratio Boost transformer fed with 120 volts and then ground one end of the secondary. Never saw one and you would probably have to make it yourself.
I have a variable transformer at my shop. It has a dial on the top that lets you drop from 120v nicely all the way down to 1 volt by turning the dial . It's all open windings so we only keep it around for no reason at all............
