I should probable know the answer to this but. Today I installed a 250v, 20amp, single recept. for a copy machine. I installed the recept. using the ground to ground and hot to each screw. and i connected it to a 2 pole 20 amp breaker on a sub panel with seperate ground and neutral bar. Every thing works fine.
My questions is I though anything electronic needs a neutral wire?
