I went into the SH the other day, and asked for a 2P AFCI breaker for a GE panel. There is a MWBC or two in a panel swapout, and the requirements for this job is that all circuits possible be AFCI protected.
Anyway, I was told that GE no longer makes 2P AFCI breakers in 15 or 20A.:blink: " use a handle tie" BTW, we don't have any of those in stock.:no:
Following it up at another competing SH, I asked if Seimens had done the same thing. To shorten the story, I found out that they stopped making the single stage models "AF" and only make the 2 stage model "AFCI". Also after a call to the Seimens rep, I found out that Seimens made the GE breakers for GE.
Didn't know that.
So, Seimens is still making the breakers, but it takes over 2 weeks to get 3-2P 20A AFCI?
Has anyone else found it hard to get GE arc faults?
If I did use a handle tie with two single pole, do the Neutrals need to be jumped together? How would that still work?
