1 - 10 of 10 Posts
So there's a receptacle in this house, one wire going to it is cut and the other goes somewhere lol
I use my pen tester and it lights up, lights up on the box and the wires. I pull out my meter and I get 0 volts between everything. I get an extension cord and plug it into a receptacle in another room. I then meter out between the ground of the extension cord and the ground wire of this receptacle box and I get 2v. Thoughts?
Senile Member
First thought no re-reading of your post. Try a wiggie instead of a digital meter and then go look for an open hot upstream.
Sounds like your ground isn't !
follow the ground wire and see where it goes
something loose, or not connected somewhere.
:whistling2:
lol. I second the wiggie for anytime a dmm gets ghost volts, picks up some induced current, or possible something backfeeding from god knows where.
The cut wire could be an issue but I'm not sure
Senile Member
Go look for an open hot upstream......
1 - 10 of 10 Posts
