PROBLEM: customer calls about a single lamp, flourescent style light not working above his built-in book case.
I arrived, turn on this light and find that just the ends are glowing red.
With the flourescent 3 ft. lamp connected to its bi-pin lamp sockets
I turn the lamp backwards and forward, and then the full brightness of
this lamp comes on.
I turn on and off the switch, and the lamp is working fine.
A week later, customer calls me, tells me the lamp is doing the same thing
as before.
Back I go back, and repeat what I did on the 1st. service call, the lamp comes back on. Run the on/off switch test, lamp comes back on each
time.
Facts: lamp, new T-12, 3-Ft. , bi-pins ends, no electronic ballast.
Any suggestions, other then selling customer a complete new luminiare.
THANKS.
this lamp comes on.
as before.
time.
THANKS.
