You can't do that if the the reels are made of ferrous materials.
Good call. A search for welding reels turned up some usable results. What do you do with the ground then? Another reel?We do it with aluminum welding cable reels. The bigger problem is making sure the reels get fully reeled out before use.
Done all the time but not with the cables on reels. Everything has to be paid out.Doesn't the movie industry do something like that when they are on location?
Maybe there's an IASTE electrician on this site who can tell you more?
Yeah 4 reels for ground sometimes 5 if its a 4 wire load.Good call. A search for welding reels turned up some usable results. What do you do with the ground then? Another reel?
