1 - 8 of 8 Posts
Hi there ,
May I please request for an answer on... How can I get a 120 vac supply voltage from a 3 phase 3 wire 240 vac panel...
You will have to get a transformer or get a neutral pulled to the panel from where it is fed.
You can't. The transformer supplying that panel is a 3 phase delta transformer with no neutral tap (X0) you would need to install a transformer to give you 120/240 3 phase 4 wire.
Any specific kind of transformer to recommend. I tried my own research ... most ask for a 480 vac input for me to get a 120/240 vac output.
Any best approach u know. Thanks
Hi there ,
I tried my own research in regards to transformer .. in order for me to transform 3 wire 240 vac input to 4 wire 120/240 vac , 3 phase transformers requires 480 vac input ... any help please
Hi there ,
There are many transformers out there that will match what you need. I belive you may be a bit over your head on this as I see you are a maintenance electrician. I think you need to hire someone familiar with this as there are many rules to follow to make the install compliant
How much 120V power do you need? You can easily get what is called a "Control Power Transformer" that will go from 240V to 120V, from 50 VA up to 5kVA, right off the shelf from any decent industrial electrical distributor.
Reactions: Big John
1 - 8 of 8 Posts
