Dead end 3 way, suicide, whatever u want to call it. Rumor has it u can no longer do it. Each box has to have a neutral in it? Code change? Where can I find it? Thanks guys.
That just shows how stupid the Index is in the Box, no direct listing404.2(C) in the 2014 NEC
thank you sirPete m. said:404.2(C) in the 2014 NEC Pete
It's not about the neutral it is about the switch and what the NEC requires for it. The book ain't easy to understand for sureThat just shows how stupid the Index is in the Box, no direct listing
as shown above under Neutral in the book!
it was in 2011 code bookIt's not about the neutral it is about the switch and what the NEC requires for it. The book ain't easy to understand for sure
You're kidding?cal1947 said:it was in 2011 code book
i dontbelieve soDeep Cover said:You're kidding?
Yes I know-- not sure what I said that prompted your response.it was in 2011 code book
fify.yes it is denny
and like you said, it's not there because of a noodle......... It's there because of the dimmer cable needing one .......~cs~
You can still do a dead end, use a 4 wireDead end 3 way, suicide, whatever u want to call it. Rumor has it u can no longer do it. Each box has to have a neutral in it? Code change? Where can I find it? Thanks guys.
What good is the neutral going to do, if the switch is on the load side of the three way circuit, unless you're going to run another load, from the switch arrangement. :001_huh:You can still do a dead end, use a 4 wire
The neutral is only there to accomodate actual currents that were traveling on the grounding conductor prior to the code change.What good is the neutral going to do, if the switch is on the load side of the three way circuit, unless you're going to run another load, from the switch arrangement. :001_huh:
Neutral required for smart switches. No such thing as three ways or four ways; it's a programming function.What good is the neutral going to do, if the switch is on the load side of the three way circuit, unless you're going to run another load, from the switch arrangement. :001_huh:
