IDK. I must be missing something here😅what about the other end of the die , even smaller ?
greenlee brand so i dont understand, unless its a labeling and therefor packing defect
30.5 mm is for buttons not pipeThey should try this, fixes the endless mistakes made by all the uneducated countries. ..............
1/2", 3/4", 1", 1-1/4", 1-1/2", 2", 2-1/2", 3", 4", 6"
But that doesn’t look like an oil tight KO.30.5 mm is for buttons not pipe
What kind is yours? I have two and they are both slug buster.But that doesn’t look like an oil tight KO.
I have an older set and it doesn’t look like that one. Does work like a champ.
His is just a plain slug buster
An older version of this. Just for the 30mm oil tight. Love my Square D switches, notch and all. They will out last meWhat kind is yours? I have two and they are both slug buster.
What is the notch nibbler? I use a jigsaw to make the notch and it is hard to keep it accurate.I just use the 30.5 slugbuster and the greenlee notch nibbler.
This is the one i have from klein. Its no longer in production. I just put it where the notch needs to be. Sqweeze the handles and it nibbles a little square notch out of the metal. Continue like sissors to make the notch longer or wider. Works like a punch, you must have an edge or hole to nibble on. Edit: They also work great for removong the little piece of metal sometimes left from a factory KO when you wiggle them.What is the notch nibbler? I use a jigsaw to make the notch and it is hard to keep it accurate.
Sent from my SM-S908U using Tapatalk
I've had mine for a long time. Pretty sure I only paid around $150.00. It will nibble any thickness you would normally cut a button into. It is very fast. Realistically, I wouldn't buy one at any price if I only had a few notches to cut. The edge of a file works well enough for that.Greenlee - Punch-Keyway Nibbler (720), Hole Making (720) https://a.co/d/hEHORwg
Struggling with the idea of a $400-600 tool when I can buy a corded or cordless nibbler for less than that that can do cutouts and more up to 14 gauge, or pay the same for the monster Milwaukee corded nibbler that does 10 gauge. Am I missing something?
Chinese Knock-off
Ok, i use a vintage Greenlee OT KO. It’s a 60249.I just use the 30.5 slugbuster and the greenlee notch nibbler.
