1 - 12 of 12 Posts
felonious smile.
Put finishing touches on this one, finally got some money again....
Would you leave a brand new $7k hot tub laying in the dirt outside for 3 months like that?
felonious smile.
felonious smile.
Your pipes crooked
I strive for perfection, doesn't always means I achieve it.
I have learned to let little things like that slide when it happens instead of wasting time trying to correct it.
felonious smile.
That has to be some of the worst plumbing I've seen in new construction.
I had to run those 2" ent's to the attic for future solar system. That was a pia going up two stories .
felonious smile.
Is that why the plumber's drain line is so crooked? He still used a coupling on a 5 foot piece though.
I had him move that whole riser originally. He placed it in my panel space. That same riser got cut and reinstalled. My elephant trunk smurftubes probably are not helping them.
felonious smile.
Discussion Starter · #12 ·
Doesn't that break fire codes?
Here we have to cap or terminate in boxes for fire code.
They are to be finished by others and routed to the exterior . I just strapped them to the plywood cause those ENTs have so much spring to them they'll mess you up.
Reactions: Hmacanada
1 - 12 of 12 Posts
