1 - 3 of 3 Posts
I have two 3/4" LBs mounted back to back. I ran 10-2 UF out of the ground then through the two LBs to get through an exterior garage wall and then into the panel located directly above the wall penetration. (Panel is inside the garage.) I'm not sure if close 90° bends in the cable like I have is in violation of the code....? Also I am unsure if these bends will potentially cause hot spots in this section of the wire. (20 amp breaker.)
1 - 3 of 3 Posts
