1 - 20 of 39 Posts
Ambassador of Amps
The ONLY line of wirenut we use. They are the best of the best.
~Matt
Spark
are these the Wago ones that you mention? (I can't figure out if you like them or not..)
Basically we usually use screw connectors here but I have recently started using these for lighting applications - 240V rated to 40A.
I own stock in FotoMat!
What happened? I haven't had any problem with them yet.
I installed about 120 can lights in a residence. They came with Wagos attached. I thought I'd give 'em a try.
Trim time comes, and half of them don't work. I spend 1½ days taking cans apart looking for the problems.
Now before you tell me I should have pulled on the wires to make sure they were set, I did. Yet a third of them still came apart between rough and trim.
Most of them had one or more wires come out. But I found two that no matter what I did, I could not get continuity through them. I wish I had saved them for forensic analysis, but I was too pissed off at the end of the day to give a shït about them.
I can see why you don't like them. Knock on wood I haven't had any problems.
1 - 20 of 39 Posts
