1 - 10 of 10 Posts
So they got these 4" cans that have ballasts on the box plate with 1-4 romex in each can. They want to change to LED. I can barely fit my fat hands in the tiny holes. I think these may bid out at 20 minutes each to take out old can, remove ballast from wiring, add the new can with the whip and close up.
I looked at other ways to do it, but only drywall breaking will speed me up, so far as I can find. Any other ideas?
· Swimmer
Replace with 6". Should give you enough room to demo the 4" stuff.
Still a pain though.
· Premium Member
They make a direct replacement and it fits the existing CFL socket. You dont even need to change or disconnect the ballast. Same lamp is good for 42,28, and all the way down to 13 watt.
PM Me!!
PM Me!!
My lighting supplier told me about these a couple of months ago. The only downside is that the LED lamps still use the CFL ballast, which will still need replacing eventually.
1 - 10 of 10 Posts
