1 - 5 of 5 Posts
I'm looking into installing a battery charger that was included with the purchase of a Army Surplus forklift. It is labeled to be set up for 480v 1ph. I always thought 480v 1ph was just using 2 of the 3 legs, but the charger is labeled L,N,G. What are they considering N? Maybe I'm just overthinking this.
Something isn't correct. To get 480v you need 2 hot legs not a neutral or 2 hot legs and a neutral...
You are correct that using 2 of the 3 hot conductors is 480V single phase....
Bilge Rat
motors and controls.........
They probably just used standard terminal labelling for all of the chargers, no matter what voltage is was setup for.
I agree.
It's like VFDs that can accept either single or 3 phase; they're all labeled L1, L2 and L3 but you'd use only 2 of them for single phase.
Check the wiring diagram & call the manufacturer if need be. It shouldn't matter, but, because of some detail it might.
Reactions: Kevin
1 - 5 of 5 Posts
