Hi everyone,
I got a call today to check out a problem at the local golf course. The irrigation pump was working this morning, then the guys shut it off to go for coffee. After coffee they went to switch it back on....nothing.
I got there and tested the voltage at the disconnect. It was 470v across L1-L2. 470v from L1-Gnd. 2v from L2-Gnd. When I turned on the disconnect and checked the voltage at the contactor and disconnect and my voltage was 25v L1-L2. 470v L1-gnd. 470v L2-gnd. I turned the disconnect off.
I was checking the fuses and then I checked the voltage again and now I was reading 240v from L1-L2 for some weird reason. So I took the golf cart to the step up 240v-->480v transformer to check the voltages and I have 484v from L1-L2.
I went back to the pump disconnect and still only 240V.
I don't know if the transformer is messed or why my voltages are changing.
I hope I explained this right.
Hope someone can help!
The motor is a 30hp 480volt 1phase beast.
