Running thread nipples aren't technically legal.Why not just use allthread? I got a hog. I'll only charge you $300...........
let me guess, UL white book? the same one that prevents us from using a threaded coupling, and EMT connector and LFMC connector to transition raceways, but we do it anyway.Running thread nipples aren't technically legal.
Yeah, I know, but I won't tell on him if you don't.Running thread nipples aren't technically legal.
Nope. The NEC. In several places.let me guess, UL white book? the same one that prevents us from using a threaded coupling, and EMT connector and LFMC connector to transition raceways, but we do it anyway.
then why is allthread conduit used by electricians?Nope. The NEC. In several places.
So a close nipple would be compliant, because it has a taper? The locknuts dont care, actually, its more difficult to get the locknuts to set on a taper.Pipe taper. Running thread doesn't taper.
I didn't write the code. Nobody trusts me . Even Miller wouldn't make me a moderator.So a close nipple would be compliant, because it has a taper? The locknuts dont care, actually, its more difficult to get the locknuts to set on a taper.
That makes sense. Now I understand why I saw that very same thing on a rigid conduit run that was installed in a very old building. I seem to remember it was 3", so im sure that would have been a very expensive erickson.Close nipples actually have taper toward the center.
There is UL listed running thread conduit that you can cut a hunk off of. Picoma (Beck) makes some. I'm just not sure how you compliantly use it.
I think the main objection to running threads came in the pre-EMT days, when installers would run a ton of thread on a pipe to spin a coupling on the whole way, and then center it up when the next piece was butted up to it, to avoid using an Erickson coupling.
Thanks for helping me scam $240 Not.......:laughing:$300??!? Y'all are crazy!
How about one for $60?
Click here to order online.
Click here for the matching locknut. only $13 more.
I have listed PVC all thread.Running thread nipples aren't technically legal.
