ABB veritron PSD 714 parameter
220 3
Please anyone can help
I have a problem reading the parameters of ABB veritron PSD 714. I can select parameter 0 up to 140, but it doesn't go down more than 10 steps, then it stops.
1 - 4 of 4 Posts
There may be a parameter you need to change to get to a different access level.
The Siemens drives I deal with have different levels of access to prevent unqualified persons from tampering with the drive.
One level of access gets into basic drive setup, where another level gets you much deeper.
Check for a parameter that will get you into more advanced programming parameters.
1 - 4 of 4 Posts
