I got an above ground permanent pool. 4 steel uprights that are really close to each other (circled in red) and then a plastic cap (with some steel pieces) covered. Nothing exposed and in order to follow with first section of 6280.26 B (2) I don’t have “minimum 4 points uniform spaced around perimeter of pool” to bond to. Then alternate means states the following;
680.26 B (2)
(b) Alternate Means. Where structural reinforcing steel is not available or is encapsulated in a nonconductive compound, a copper conductor(s) shall be utilized where the following requirements are met:
(1) At least one minimum 8 AWG bare solid copper conductor shall be provided.
(2) The conductors shall follow the contour of the perimeter surface.
(3) Only listed splices shall be permitted.
(4) The required conductor shall be 450 mm to 600 mm (18 in.
to 24 in.) from the inside walls of the pool.
(5) The required conductor shall be secured within or under the perimeter surface 100 mm to 150 mm (4 in. to 6 in.)
below the subgrade.
(3) Metallic Components. All metallic parts of the pool structure, including reinforcing metal not addressed in 680.26(B)(1) (a), shall be bonded. Where reinforcing steel is encapsulated with a non-conductive compound, the reinforcing steel shall not be required to be bonded.
So does that mean just installed around perimeter bonded to motor lug and skimmer plate and that will suffice? Above ground pools are the most confusing and to me.
680.26 B (2)
below the subgrade.
