Something I've never done, wondering what the best way to do this is in Manitoba:
Customer wants to add a new panel to a tarp shed(30x60) about 40ft from the hydro pole that has all his overhead feeds to other buildings. I have nothing to build a mast off of, and its an area he drives sprayers and other equipment thru, so I want to feed it underground from the shed to the pole with ACWU, and run up the side of the pole to the top, but how do I transition out of the armour? Wet Connector-coupler<>emt wet connector<>short length of emt<>service head?
Thought about just sliding a conduit with service head over the end of the ACWU, but that doesn't seem right with the cable just floating inside with no bushings of any kind on the cable.
I have also seen pictures of a heatshrink boot that has individual holes per conductor out the top, so that maybe would be an option.
Thanks
Thanks
