1 - 8 of 8 Posts
I have an air compressor with dual 7 1/2 hp single phase 240v motors. I will have 4 conductors for the compressor (separate circuits) and a 120v lighting circuit in 1 conduit. I will need to de-rate by 80% due to 4-6 conductors in the conduit, #8 @ 90degree is 55amps by 80% is 44amps. The motor table list a 7 1/2 hp @ 40 amps is there another multiplier I have to add to the 40amps or is the #8thhn sufficient. The air compressor has a device that during each run it switches motors but in a rare case they both could run at the same time.
By what rule are you using the 90C rating of the conductors?
Coffee drinking member
Size them to account for both to start/run at the same time. Sooner or later they will. Wire sizing should be in the compressor package. If its a Quincy hit their site and they have just about every package waiting as a PDF.
regardless of manufacturer the all usually carry the info you would need for their equipment
Reactions: Wirenuting
I wanted to just mention Quincy as they have a good library. They even still put up items that long ago went obsolete.
god i know what you mean :eek:we have a couple quincy's at the plants air building and weve had to look up info there before:laughing:
Bilge Rat
motors and controls.........
You're right about 40 amps each.
430.21(A) states that the table values need to be multiplied by 1.25 for a single motor, so 40 X 1.25 = 50.
If you're using THHN, 310.16 lists #8 at 55 amps at 90ºC; 55 X .8 = 44. But 50 is needed.
#6 is 75 amps at 90ºC, so it will derate to 60. This is the minimum size needed.
Just for info, Table 430.52 allows a basic standard circuit breaker to be 250% of the table current. In this case, 40 X 2.5 = 100. This is the maximum breaker, there is no minimum.
If you're using fuses, it's be 40 X 1.75 = 70. This is the maximum size for basic time-delay fuses. Again, there is no minimum.
1 - 8 of 8 Posts
