Maximumbob said:
What area and what price point are these homes? Beside the service, what do you have to do/finish? Thanks
I'm in a flood zone so my houses are typically about 8-15 ft off the ground on pilings, the service must also be one foot above flood so the meter is about 6-15 ft off the ground
Run ground for csst gas bond
Run the home runs into the panel
The service
Home run to furnace and wire
Home run to ac unit and wire
Tie in connections from box to box.
Install inside and outside lights.
Install ceiling fans.
Cut in and install outlet for kitchen island
Put covers on devices that are missing.
Install keyless and outlet in attic.
Install pull chain and outlet in crawlspace or wire underneath( usually about six keyless, few outlets and a coach light or two)
Minor troubleshooting ( something is always messed up from the factory)
A two box 3 bedroom ranch is about $900 in material and takes about 40 man hours.
You can add about 4-5 hours to that per additional box plus another furnace and ac unit if it's going to add another zone.
