I want to have separate controls by the panel for each AH relay...Why do you need a RIB? Just interrupt the 24 volts and be done with it.
I guess I'm not following what you're trying to do then. It seems to me that Altronix relay would do the job without using another relay.I want to have separate controls by the panel for each AH relay...
The AH are line voltage.. RIB's are made for that..I guess I'm not following what you're trying to do then. It seems to me that Altronix relay would do the job without using another relay.
Stop killing the line voltage, do it right and kill the control circuit.The AH are line voltage.. RIB's are made for that..
I like the idea of having LED's showing the AH is disconnected during a FA test..
That's like asking him to load his truck with electrical tools and material. Being an electrician just isn't in his forte.Stop killing the line voltage, do it right and kill the control circuit.
We have been though this already.. some AH keep running when you kill the control voltage...Stop killing the line voltage, do it right and kill the control circuit.
Go sit in the corner and pull your pork.. you seem stressed out..I think it's just plain wrong for people's lives to depend on B4T's jury-rigging.
Bullchit.We have been though this already.. some AH keep running when you kill the control voltage...
Even a loud mouth asshole like you can be wrong.. :no::no:Bullchit.
You just can't figure out how they are wired.
Yes that is most of them.Some units keep running to dissipate the heat after the stat has reached temperature..
Which proves you don't know what you are doing.I went directly to the CT and the unit still kept running..
CT supplies power to RED of stat.. this is how small units are wired,,Which proves you don't know what you are doing.
It is a small unit, yet you cannot figure out what controls the fan.CT supplies power to RED of stat.. this is how small units are wired,,
Breaking the RED does nothing.. it USED to work just fine.....
You're still a loud mouth asshole.. :thumbsup:
This is from the thread I ran.. http://www.electriciantalk.com/f2/air-handler-fa-cutoff-56923/index3/#post1052070
That was the first thing I tried you moron.. it did nothing.. stop being a jerk.. :no::no:It is a small unit, yet you cannot figure out what controls the fan.
I think that says a lot ....
What controls the fan?That was the first thing I tried you moron.. it did nothing.. stop being a jerk.. :no::no:
Many sure doa lot of commercial units made this century have a built in set of terminals for that specific purpose. you checked the literature, didn't you ? (not trying to be a smart a$$) (you could also just buy a 7 pole contactor)
