NEC doesn't specify a distance. Some local codes do.
Yes.just remembered that after posting...thanks!
I'm getting ready to do a meter relocation which will cause the SE cable to be about 60' to panel after it leaves the meter so ill have to set disconnect outside. Does the disconnect have to be a fused disconnect?
