If the motor is started across the lines, instead of a full-fledged soft-start, I've used Allen Bradley STC (bulletin 154) soft-starts. (JRaef, help me out here, it's sort of a distant memory and I may have the numbers wrong......lol)
This type of starter is installed downstream of the regular across-the-lines starter. When the starter closes, this device brings the motor up slower than blasting it with full voltage. It resets itself when the starter opens.
I don't know if it can catch a spinning motor or not.
And no, I don't work for Allen Bradley, I simply use their stuff whenever it's my decision, and I know their product lines. I'm pretty sure other manufacturers make the same item.
Rob
