Ok, so I know most people don't care when the lights dim when high draw appliances kick on, but I do. I'm wondering if I can get this worked out by installing capacitor on high draw circuits. I only have a 100amp single phase service, which is more than enough for my little ranch style 1300ft2 house. I just want to get this thing into perfect shape and need never touch wires in it in my lifetime. So... What do you guys think? Are capacitors the answer....
More info, it's 100amp Square D 32 space panel running 30 circuits. Load test on house was 81.2 amps when I had every stinking electrical device I own on and running constant, so I'm not over board, except for inrush when motors kick start. I'm hooked to meter with 1/0 thwn and every lug and screw is torqued to spec... Yes I was on anal run, but hey annual torquing keeps the fire away. Every circuit is correctly sized if no oversized on all major appliances I.e. Stove, AC, Compressor, disposal, dryer, washer, etc.
