Any help would be appreciated. I'm trying to pin down an approximate date for this:
#historyhouse lol40’s maybe into the early 50’s. If it’s yours you need to do some updates because those 30 amp Edison base fuses will make your house become history @HistoryGuy.
#Blazeofglory#historyhouse lol
Lol!#Blazeofglory
Could have bigger wire in the walls.40’s maybe into the early 50’s. If it’s yours you need to do some updates because those 30 amp Edison base fuses will make your house become history @HistoryGuy.
2 digit "postal zones", started in 1943probably right after knob and tube started
just a guess
one clue might be that it says Brooklyn 11 NY
find out when that designation went away and you will know its older than that
Could but not likely.Could have bigger wire in the walls.
