This is off of shelf lights for a display freezer. It's a older unit cannot find the model number. I just need a few of these plugs
And burned crispy.broken. its called broken.
It's 120, these are off of a big round freezer. With multiple shelves. Three layers of shelves all around it and each 4 ft shelf has a light on it.What's the voltage? You might be stuck with replacing with an alternate. Is the fixture in the door of the freezer and that's how it plugs in?
I will look tomorrow morning at the shop. I have some, just not sure they are the same.This is off of shelf lights for a display freezer. It's a older unit cannot find the model number. I just need a few of these plugs View attachment 161712
I just googled ”broken connector”…. it didn’t look like that lol!broken. its called broken.
How about you let us see the lamp?This is off of shelf lights for a display freezer. It's a older unit cannot find the model number. I just need a few of these plugs View attachment 161712
What I have looks like this.This is off of shelf lights for a display freezer. It's a older unit cannot find the model number. I just need a few of these plugs View attachment 161712
What I have looks like this the square is an inch .This is off of shelf lights for a display freezer. It's a older unit cannot find the model number. I just need a few of these plugs View attachment 161712
I call it meltedbroken. its called broken.
Problem with these is they aren't tight to wash down, which should happen daily.View attachment 161743
I would probably just replace them with IEC inlets / plugs as they are standardized and available all over the place
