1 - 17 of 17 Posts
I never used these boxes cause they're a bit pricey but I'm doing a rewire in plaster/lath house and I'm loving them. Probably still use old work box with madison bars in drywall but these are great right now.
felonious smile.
No internal clamps, miserable.
I prefer Slater old work provided nm is used.
Am I the only one that likes the heavy duty " hard shell " carlon old work boxes ? For commercial work I'll use metal boxes with Madison bars , but as far as residential goes , I'm not putting in a metal box when everything else in the place , is plastic or fiberglass . A tip for the flip out wing old works is to run the screws in all the way through the wing , before installation so you're not fighting and rounding off the heads on the garbage screws they use .
Chrisibew440 said:
Absolutely. Just wait till you have to shove a gfci in their.
It will work , but I recommend running in the unused screws and taping over the terminal , to avoid a spark show , lol .
Armed and Unhinged
I use plastics in resi
What do you use in plaster/lathe walls?
We always use Slater plastic cut it boxes when using NM. The tabs are set back far enough for plaster/lathe.
I always hated fumbling with those side tabs and they took up valuable space in the already narrow metal box.
1 - 17 of 17 Posts
