Booooo boooo deepcover booooooo.
Says the guy who started the #14 VS #12 thread.:whistling2:Booooo boooo deepcover booooooo.
I was having a nice day untill you reminded me AFCI's exist now im a little dead inside.Says the guy who started the #14 VS #12 thread.:whistling2:
Then I ask...why are some areas excluded? A specific example would be outside receptacles.Arc Fault breakers are supposed to protect the wiring within the walls as well as anything externally connected. It provided both parallel and series faults.
The same reason you told your prom date you only wanted to play just the tip.Then I ask...why are some areas excluded? A specific example would be outside receptacles.
During the '99 review, i asked the same basic q's here. (Vt was a code cycle ahead of the nation with 210.12B) 14 years later, i STILL have no viable answerAt a recent 2011 code seminar, I asked a question to a couple fellow electricians and no one could give a good answer.
What is the end purpose of AFCI's? Is it for the home wiring or to protect against faults with what is connected to the home wiring? Both?
The reason I ask is that I am trying to figure out why certain areas of the home are exempt from the AFCI requirement. I understand 2014 eliminates many of those areas, but there are still some areas exempt.
Because the guy who invented the arc fault breaker hasn't gotten around to burning something outside and blaming it on an arc fault fire.Then I ask...why are some areas excluded? A specific example would be outside receptacles.
To help manufacturers make more profit in the residential market. Even if a house is wired code minimum the required circuits alone will generate breaker revenues then if the house was wired with extra circuits using 3 buck breakers.At a recent 2011 code seminar, I asked a question to a couple fellow electricians and no one could give a good answer.
Oh no, corporations are never corrupt and are as pure as the driven snow.To help manufacturers make more profit in the residential market. Even if a house is wired code minimum the required circuits alone will generate breaker revenues then if the house was wired with extra circuits using 3 buck breakers.
The theory pelted around should an arc form from say a frayed cord or a nail pierced romex the arc along with the resulting fire would be stopped.
Im sure in the next code cycle commercial areas will ask for it with the next code cycle wanting it on all resi 240 volt circuits while the next code cycle after that wants them everywhere. People will blindly obey and believe, while Cutler Hammer celebrates the power of covert bribery.
That's exactly what I said.I think they were always planning to phase it in. I think bath areas are not in because they don't want people to be in a shower and have the lights go off on them. Just a guess. Perhaps someday they will also be included. Not sure why unfinished basement areas are excluded but I bet they won't be soon.
Well if you listen to CS you will be held reponsable for installing NEC required and listed equipment that did not work. I think that is ridiculous.I'm curious, what happens when a home burns to the ground due to arcing that an AFCI doesn't detect?
Which part? Do you think they do that? Or do you think they wont? I don't know what to think about liability any more.Well if you listen to CS you will be held reponsable for installing NEC required and listed equipment that did not work. I think that is ridiculous.
In my opinion the chances of an EC being found responsible by the courts for the failure of an AFCI to do its job is so remote that it does not merit worrying about.Which part? Do you think they do that? Or do you think they wont? I don't know what to think about liability any more.
Everyones off the hook. To start with it would be difficult to prove an arc fault started it, second when the fire starts it will melt/destroy everything within sight, breaker will probably trip any ways along with all the evidence of what caused the arc being burned up.So what seems to be the fact is that WE are their testing/quality control department. They dont require all area because it is an unproven technology. They make more money while we eat the warranty labor.
