"Normal" feeders? I would say NO, avoid the room.
Obviously the Gen feeders must get out of the source to the ats.
is this as opposed to the line side of the generator:whistling2:goose134: I didn't describe the feeders correctly. The conduits running through the room are actually the load side of the generator.
transfer switch and their associated dist. The feed from the genset to the ATS is not "their associated distribution". It is the feeders to the ATS, obviously....(4) transfer switches and their associated distribution shall not be located in the same room as the generator or service equipment
Yes, I see the folly of my statement. But you're right, the feeders I'm referring to are the emergency connections. I'm hoping that the normal feeds still are not in the room. So many walls have changed places recently, it's hard to tell. Nothing on a print, mind you, just conversations.is this as opposed to the line side of the generator:whistling2:
