1 - 4 of 4 Posts
article 225.30 requires a single feeder be ran when served by one feeder, if the building has multiple feeders on same building. according to Article 225.30 E. and 225.37 identified its ok to feed a building from multiple feeders. anyone have experience with that?
evil bastard
There are 6 special conditions that you can do this. If it's not for any of those six, you can only do it if you need more than 2000 amps at a seperate structure.
Yes. For EX.,multiple structures can have 208/120 feeders and branch circuits exclusive to 277 lighting from one source, but need to be identified in each structure w/disconnecting means. ~CS~
Manny (MBLES)-- here we go again hey...:)
Go back and read that section-- it does not say that. It states that only one feeder or branch circuit may feed the building and there are exception.
according to Article 225.30 E. and 225.37 identified its ok to feed a building from multiple feeders. /QUOTE]
Yes this was covered above-- the exceptions
1 - 4 of 4 Posts
