Sure isn't. The print on all four sides of the box is identical. The top is missing and the bottom is blank. I want to say its circa 1972 or earlier.Is there a price on it?
I know you'll say they work fine but how do you keep from damaging the wire? Around here you'll only see them on old BX or something like that. Some of the old Romex was installed with 2-hole straps but other than that it's mostly plastic staples up here.They wouldn't rust in an attic around here. I rarely use anything other than a metal staple.
What do you use to staple wires?I seriously believe you too. Up here on the frozen tundra it might be considered hack! I've never even seen them for sale at the supply house or elsewhere.
Wire staples!What do you use to staple wires?
Metal staples are used up here for fencing........We use nothing but metal staples. You just gotta be smarter then the hammer!
How many 12-2's are the metal staples listed for?We use nothing but metal staples. You just gotta be smarter then the hammer!
if youre stapling single #12s youre doing something wrong anywayHow many #12's are the metal staples listed for?
I nail a staple, then run a piece of 14 or 12 thru it and around the wires. So I guess as many as the framing cavity will hold.wendon said:How many #12's are the metal staples listed for?
