1 - 1 of 1 Posts
Running a 460 volt 3/ph , 1 hp , 1.8 amp motor with a baldor H2 inverter in the v/f mode and the motor will run fine if you hand start it. But it will NOT start on it's own. Checked the settings and all looks good and did teh "Calc motor" It found and correct the MAG amps from 2.4 to .9 but that did not solve the issue. Anybody else had this issue and found the answer? Would appreciate any info . PS the motor is free spinning and wired correctly , not binding up .
1 - 1 of 1 Posts
